Questions from a new owner
Hi all,
last friday i purchased a 2003 suburban z71. overall its in good shape. I has a small oil and trans leak, and one of the front rotors is warped. I had it inspected by a local shop yesterday and aside from the leak and the brakes it received a clean bill of health.
There are a few things that while probably not "This has to be fixed" issues, are things i want to deal with. I have a few hundred dollars left over out of the budget i had to buy it and figure i might as well handle them now before the newness wears off.
1. There is a kind of rattle in the steering, i can feel it in the wheel more than hear it. Ive been told the idler arm on these trucks go bad. Id really like to fix whatever is causing this.
2. Mirror selector switch: The mirror selector switch doesnt want to switch between mirrors without a lot of prodding.I was thinking of pulling the switch off and soaking it in some alcohol. any other suggestions?
3. More of a question than an issue, is there anything special in terms of brake parts i would buy since this is a z71?
Use specific electronics contact cleaner on the switch. Do not soak it in alcohol.
Nothing special about a Z71, just use the listed name brand replacement brake parts on it.
Don't assume on front end parts. Every joint needs to be inspected for wear or binding. Power steering fluid may need a suck out and refill also. Use the correct stuff, GM not the universal leak stopper junk at the parts store.
I am planning to to an oil change and trans fluid swap. Im a fan of liquimolly, and im thinking of using their engine and trans fluids.I know for the Transfer case i have to use the GM brand fluids, Thanks for the heads up on the power steering fluid.
Struts and shocks have a electrical connector that wiring plugs into the shock. My Tahoe as it and also auto leveling which is electronic shocks on the rear that are air shocks also.
