Radiator fan running at startup
Old Feb 18, 2016 | 11:31 AM
Bossman140's Avatar
Default Radiator fan running at startup
New member here. Any suggestions would be much appreciated.
Last night when I started my 2000 Suburban in 29F weather, the radiator fan came on and stayed on till I shut the car off. I only noticed it last night. I purchased the car about 2 months ago and never noticed this before.
The car was sitting for more than 24 hours. My AC and defroster were both off.
Any ideas as to what I should be looking at? Coolant temperature sensor? Relay? Thermostat?
The car warms up fine and does not overheat. Runs at normal operating temp.
This car has been a nightmare and at this point, I have pumped as much $ into it as I paid for it ($3800).
Had to rebuild the tranny 2 weeks after I got it.
Again, any insight would be appreciated.
Old Feb 18, 2016 | 11:41 AM
Scotiapilot's Avatar
temp sensor, test it.
Old Feb 18, 2016 | 12:01 PM
Bossman140's Avatar
Thank You.
Will check that first.
Old Feb 18, 2016 | 1:04 PM
Bossman140's Avatar
Just one more thing.
The SES light is NOT on. Wouldn't the failing sensor throw a code?
Old Feb 19, 2016 | 9:46 AM
no, not always. if we lived in the sahara and it was hot all the time or cold all the time it would throw codes.
I am open to be corrected by the other fellas here.
