Radiator leak at upper radiator hose
Old Mar 15, 2018 | 11:56 PM
PapaHepcat's Avatar
Default Radiator leak at upper radiator hose
My Burb leaks coolant at the connector for the upper radiator hose. I replaced the old hose recently, and when I put on the new one, I noticed that the connector wasn't round.
I've tried tightening the new hose really good, two clamps at a time, and putting some sealant between the hose and the connector, but no dice. Is there a good way to do this, or should I just replace the radiator?
Old Mar 16, 2018 | 1:51 PM
If it is radiator with plastic end tanks, those can be replaced without replacing the entire radiator. If it's a standard brass radiator, it can be repaired. Both would require removal from the vehicle.
