Radio problems
OK Sorry, now you're getting too high tech for me, I don't know what Tech-2 or SiS is. I assume that is adealer only service (the programming). But, I have only had the truck for about 4 months. The radio and all speakers were working fine, until one day (2 months after I bought it)the audio would start to cut out. It is intermittent. On the way to work this morning, the audio worked for about half the drive and dead the rest. The audio for the rear did also work when the rest of the audio was working. One day it works, the next it doesn't.... grrrr!!!
ZX - TX again.
Tomorrow I am bringing it inside the shop at work (it is freezing here), and I will do all the checks you mentioned as well as check all the connections for any loose wires. I wil keep you posted.
TX
Marc
TX
Marc
Ijust had a similar problem with 99 suburban. I have installed clarion deck but all of sudden no sound would come from any speakers. I switched the deck with factory unit and still no sound. I wiggled amp plug with no result. I removed the harness from the back of the stereo and found that the right rear speaker wires were shorted to the body of truck. The rear speaker wires on my model go from the stereo to the factory amp so removed amp plug and checked again and still was shorted. I cut the right rear speaker wires both on the factory amp side and the stereo side and ran new wire which corrected the problem.
If one of the speakers is shorted to the body, sound will not come out of any speaker. Although stereo will turn on. Check your wiring diagram for the speaker wire colors and check for continuity between them and ground using an ohmmeter at the harness behind stereo and then trace from there.
I have a 2004 Chevy Suburban Z71 with the Bose factory system and have the same issue. I haven't been able to check anything on it. I wanted to see where do I start? My truck has no sound, and it keeps marking to check the tire monitor and air bag.
Occassionally, when I get in my 04 Tahoe Z71 (Bose) the radio will not produce sound although it will appear to be working fine. There is a clicking noise that I hear from the front driver corner of the dash that is very cyclic about once per second. If I hear that sound, the radio will not produce sound. Sometimes I can turn off the truck, open the door, remove the key, fiddle with the memory seats, and then turn it back on and it will start working. Other times when that doesn't work, it may spontaneously come on after several minutes. It seems worse when it is warm or hot out. I suspect something with the amp but thought I would check with the forum...
Thanks.
Silence is Not Golden...
Thanks.
I recently changed factory head unit with cheap dual brand head unit everything was workin fine till tuner went out then changed dual head unit with jvc the 04 Tahoe has Bose system in it now door speakers wanna pop an crackle an never did with dual only when I changed to jvc any suggestions got me stumped
