Raise rear to fill transfer?
Old Jul 31, 2011 | 7:20 AM
dmatre's Avatar
Question Raise rear to fill transfer?
2002 Suburban, changed transfer with Auto Trac II, manual calls for two quarts, I measured what I drained and it was right at 2 quarts, when I filled it with vehicle level it started running out of fill whole at about 1.75 quarts.
Wondering if I should raise the rear and put the last 8 ounces in or leave it as is?
Thanks,
Don
Old Jul 31, 2011 | 3:42 PM
saxart's Avatar
I've never heard of "raising the rear" of a vehicle to get all of the fluid in. Usually I just fill it until it tops out, then put the plug in and call it good. Maybe it was "overfilled" the first time?
If you put 1.75 quarts in, you should only have 4 ounces to get to 2-quarts, not 8-ounces.
One more thing... Could your rear springs be sagging? That could cause your fill amounts to be different, but not by much.
Old Jul 31, 2011 | 4:15 PM
kevinkpk's Avatar
You might put in 4wd, drive it around the block, then see if it will handle the last part of quart.
Old Jul 31, 2011 | 4:24 PM
dmatre's Avatar
32/4 = 8
.25 quart =8oz
Good call on driving a few miles and then topping off, found the same thing on another source. Going to try it in a few minutes. Vehicle was level on stands when I changed it.
Thanks,
Don
Old Jul 31, 2011 | 5:53 PM
dmatre's Avatar
Drove around about 15 minutes, shifted in and out of all transfer ranges a couple of times each, pulled the fill plug it didn't run out. Pumped a little in and it started to run out right away, gave it a couple of good full hard pumps and put the plug back. Had 8 ounces left of the 2 quarts, now down to 4, probably put 2 in the case and 2 on the paper I had under it.
Was reading on other boards that it is common to use 5w30 synthetic motor oil and fill with 3 quarts through the speed sensor on top. Maybe somebody filled it that way previously and that is how I got two quarts out when I drained it. It did seem over filled, because I removed the fill plug first, to make sure it would come out with no problem before I had an empty case, and it came out pretty fast as soon as I got the plug out.
At least now I know it is topped off.
Decohead
May 7, 2010 1:30 PM
Raditude
Nov 20, 2009 1:51 AM
handrade_satx
May 31, 2009 9:49 PM
handrade_satx
May 21, 2009 12:04 AM
mitchell03
Mar 5, 2008 10:30 PM
