ramps
Old Apr 13, 2008 | 11:53 AM
oniscus's Avatar
Default ramps
i need a good set of wide ramps got 285/40/24 and i measured the width of the tire and it was almost 11 inches, where can i find a wide enough ramp to lift the front for oil change. got a big jack but ramp will be easier.
thank you
Old Apr 13, 2008 | 3:19 PM
mary900's Avatar
Default RE: ramps
You may want to consider either RV and/or semi-truck ramps.
http://www.discountramps.com/wheel-risers.htm
Old Apr 15, 2008 | 4:12 PM
RonH's Avatar
Default RE: ramps
I was in Advance Auto Parts today, and they have some black plastic ramps that look like they would work. I didn't stop to look or measure, but they must be 14 - 15" wide.
Old Apr 15, 2008 | 10:06 PM
OmarR's Avatar
Default RE: ramps
The Rhino Ramps that are carried in auto parts stores are 11 inches wide. I just measured mine.
Old Apr 17, 2008 | 3:16 AM
oniscus's Avatar
Default RE: ramps
thanks for all the info, saw one oddly enough at walmart that was 12" wide and its only $40 might pick it up this weekend
Old Apr 17, 2008 | 6:54 PM
Default RE: ramps
Not sure I'd want to crawl under a three ton truck sitting on plastic ramps. []
Old Apr 17, 2008 | 10:49 PM
RonH's Avatar
Default RE: ramps
ORIGINAL: OmarR
There are two ramps made by Rhino in Advance Auto and probably most other auto stores. The one is 11 inches wide and the other, higher rated set is 13 or 14" inches wide.
Old Apr 18, 2008 | 12:26 AM
oniscus's Avatar
Default RE: ramps
very good point,i'll put some jack stands also just to be safe.
Chevrolet Forum News
Jun 24, 2015 6:48 PM
SgtChevy
Jul 11, 2012 8:03 PM
