rattle in driver rear door
Old Apr 26, 2010 | 10:01 PM
ChevyguyArmen's Avatar
Default rattle in driver rear door
I have a rattle in my driver side rear door and I can not find it!!
I thought it was the seat belt pulley in the section between the two doors. I took it to the dealer and they adjusted it. It is still making the same rattle. Sometimes it is louder than others. I have felt all around the door and can not find anything loose. It almost sounds like the window bouncing inside the door panel but the window is not loose. I guess I will just have to take back to the dealer while I have some factory warranty left. Any ideas as to what it could be??
Old Apr 27, 2010 | 8:26 AM
LARIDERS's Avatar
if you have the small light in the door at the bottom that might be it. I had a rattle in one of my doors turned out to be a loose bolt. one of the bolts that hold the window motor in.
Old Apr 27, 2010 | 8:48 AM
no I dont have the light. I tried everything and I don't want to take the door panel off and mess it up even more. I guess I'll take to the dealer but Im sure they won;t find it.
JustinL
Aug 23, 2014 12:54 PM
SabrToothSqrl
Jan 23, 2012 12:11 PM
cjeff
Jan 17, 2009 6:54 AM
WilliamYoung
Uplander
Dec 31, 2008 6:36 PM
sudo
Mar 22, 2007 5:51 PM
