Rear Barn Doors Seldom Lock with remote
Have a 2001 Suburban Base Model (Work Truck) with barn door rear doors. For the past couple of years, I have noticed that when I use the keyless remote door lock, the back doors do not lock. I can lock with a key. Any ideas where to check? Clean?
David
David
Not sure on a '01 but on my '99 when you open the door you will see some ''pins'' sticking out in the door frame. Those are the connectors for the power to the doors. Clean and silicone grease on the ends.
I have a 2001 GMC Yukon XL, barn doors. I bought it about 5 years ago. The first thing I did was make a list of things that had to be done. Most of them were little piddly things, such as broken antenna, radio **** missing, power window not working and barn doors not locking with the FOB. I got everything fixed except for the barn doors not working. I changed everything: the actuators, the contacts and anything else. I could never figure it out. So I just lived with it.
My wife drove down the driveway when it was dark. Just happened to notice, one of the license plate lights was not working. The next day, I replaced the bulb; all better. That same day when I went to lock the car (I would manually lock the barn doors, and FOB lock the rest), I noticed that all the lights flashed. It had never done that before. Low and behold the barn doors locked. I was stunned.
I can't explain what happened but from the time I replaced the bulb, the barn doors have locked. That's been over 3 years. Go figure.
Check your number plate lights.
Tom
Tom
twoshoes
February 24th, 2022 5:10 PM
99 Chevy
August 4th, 2017 1:07 PM
