Rear A/c Blowing Hot...Clicking sounds near back panel
Old Jul 31, 2024 | 12:04 PM
cmavendano's Avatar
Exclamation Rear A/c Blowing Hot...Clicking sounds near back panel
So i was told that i most likely need to replace the AC Heater Blend Door Actuator. Sounds doable...however This particular model has both actuators between the blower and the exterior panel. ugh. So assuming that i can even get the screws removed, is this something that would require hvac refilling and stuff??? Or can I simply remove the old part and replace it with a new one?
Old Jul 31, 2024 | 1:39 PM
jfmorris's Avatar
Replacing blend door actuators should have no impact on the coolant charge in the system. I.e. you are not touching the refrigerant lines.
Cusser
Aug 8, 2023 1:38 PM
Kristie Reid
Mar 12, 2018 9:59 PM
Xile
Jun 22, 2011 7:36 PM
garmillio
Jan 6, 2011 9:08 PM
Venge
K5 Blazer
Nov 24, 2008 7:53 PM
