Rear A/C won't blow air out of vents and mirror issues
So I just bought a used 2004 Suburban Z71 and have had a few small issues. The rear vents have no air coming out of them no matter what setting the front controls are set in. Any suggestions as to how to trouble shoot?
Also, might be related, my rear view mirror won't display the temperature or travel direction while the onstar and auto-dimming features are working. Tried to find the fuses for this but no luck. Any suggestions?
Thank you!
Thank you!
Former Sponsor
If you can hear the fan running but no air, you've got a bad "mode" door motor. If the ac blower motor isn't running, it's either a bad fuse, bad blower motor, or bad blower motor resistor.
This is a new (used) car for me so could have some demons
re-check all the fuses, did the previous owner have any aftermarket items installed/removed, if so check the wiring around those items.
Check the under hood relays also...
Gain access to the rear fan assembly and check for voltage at the fan with the rear AC enabled... if you get voltage then you know the fan is most likely out...if no voltage then an open fuse or broken circuit exists....
1) Where is the rear AC fan?
2) Is there such an occurrence that if the freon (or what ever is in the AC system) is low, it will auto-shut off?
My rear AC blower won't turn on. I have a 2004 suburban with auto rear AC. Here is the strange part: the rear blower is getting ~2.5 volts in the power cable and ~1.3 volts in the black(ground). The resistor has both a 12 volt power and a good ground but the middle wire (input) is reading a very light .05 volts.... That seems wrong.
All of the fuses are fine and the system is turned on to full AC. Any thoughts?
jbbcd
August 17th, 2015 9:29 PM
Boverman93
Traverse
January 7th, 2015 11:32 PM
cris2for
July 25th, 2010 1:04 AM
