rear end noise
Old Sep 19, 2013 | 9:33 PM
hunterjo's Avatar
Unhappy rear end noise
i have 2001 sudurban 1500. had rear end problem and replaced ring gear &pinion and all bearings. ended up with a winn noise on coast and a vibration at 65mph and above. put in another ring&pinion and new pinion bearings. istill have same problem. when apart i took run out on axle stafts it was up to .030 wobble(i chucked them up in a lath) on both axles. could this be my problem or something else.
Old Sep 19, 2013 | 9:47 PM
I don't know about the whining sound but I could see the vibration coming from your efforts to true up the shaft(s)... they may be perfectly round now, but may be out of balance... I guess it would depend on how much material was removed..
Old Sep 20, 2013 | 12:43 AM
Jabster159's Avatar
did this happen after the ring gear and pinion were installed? do ur new gear ratios in the rear match the front? if this is a 4wheel drive.
Old Sep 20, 2013 | 7:09 AM
hunterjo's Avatar
just to make things straight i did not turn down the axles i just used a dial indicator to check straightness. yes the problem started after the rear end came apart after the carrier bearings failed. yes i still have same gear ratios. does anyone know what is allowed run out on axles?
TASpinney9110
Mar 15, 2011 5:54 PM
hydrodriver
Astro
Dec 11, 2010 8:52 AM
Flyfishtrip
Jul 8, 2009 11:23 AM
tc3457
Jan 26, 2009 6:13 AM
