Rear Heat...
Old Nov 11, 2010 | 9:12 PM
schlepprock379's Avatar
Default Rear Heat...
Hey guys,my wifes Tahoe('04 5.3),she says the rear heater doesn't put out heat untill you start going,I'm thinking clogged rear heater core.I've read/heard that the Dex-cool coolant can cause clogging issues,I plan on removing the rear heater core,doing a full system flush,changing upper and lower rad hoses as well as t-stat,I have about 5 or 6 gallons of red"elc" coolant left over from doing my truck(7.3 diesel),is it ok to run red elc coolant in a 5.3?....Thoughts...thanks phil
Old Nov 12, 2010 | 12:06 PM
Don't know what red elc is but I know that the problem is mixing any other antifreeze w/ Dexcool. It causes it to gel.
Old Nov 12, 2010 | 12:41 PM
"elc" is Extended Life Coolant I'm guessing different manufactures have there own color schemes....but I am sure they are also chemically different for patent reasons so I would be cautious on mixing them.
Old Nov 12, 2010 | 12:55 PM
gotstylez's Avatar
when u flush the coolant system put in some dish soap....did it when i flushed mine about 2 months ago....there was so much crap that came out..just make sure u clean it a extra few times...
Old Nov 13, 2010 | 7:55 PM
Thanks guys,I definatly plan on doing a very thorough flush before I add the ELC,I wasn't gonna mix it with the dexcool,I know that with some diesels you can't use an ELC coolant,I just wanted to see if anyone knew for sure whether it was compatible or not.
RHYS
Uplander
15
Dec 28, 2021 8:25 AM
Chevmann92
Jan 3, 2014 2:03 AM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
