Rear heat/ac control display
Old Feb 7, 2011 | 12:14 PM
blueskies's Avatar
Default Rear heat/ac control display
Hi all, new to the forum...
Just bought a used 2007 Suburban LT with all the options except the NAV. 60k miles.
Just noticed last night that the rear heat/ac control digital display, located at the back of the front center console, is so dim that I can barely see it. At first glance, it looks like it is not working at all. I have to cup my hands over it and look real close to see if the rear seat heat is on, etc.
The control buttons work fine for everything, it's just the display that is not working.
Wondering if there is a contrast/brightness adjustment somewhere for this, or if it has just failed.
If it is bad, is this a dealer only item? Where can I look up a part number?
Thanks for the help...
Pete
Old Feb 7, 2011 | 12:37 PM
Welcome to the forum.
Haven't checked but does the dash dimmer also turn these down? Might check. It's the little know to the left of the steering wheel that you push in to pop it out and rotate to dim or brighten the lites.
Old Feb 8, 2011 | 11:18 AM
blueskies's Avatar
Thanks for the reply-
I tried adjusting the dash dimmer, didn't seem to make any difference... I thought that was the problem at first, because I had the dash dimmed down to it's lowest setting. I turned it back up to bright, but the display on the rear control is still so faint that it looks off at first glance...
Pete
Old Feb 8, 2011 | 5:48 PM
Yeah, I checked mine and the dimmer has no apparent effect on the RSE illumination.
Old May 12, 2011 | 8:40 PM
gamecock's Avatar
I am having this same problem if anyone has any ideas. Just bought a 2007 LTZ today
Old May 13, 2011 | 8:40 AM
gamecock's Avatar
Got a quote from the dealership for the part as $304.50 - does that sounds about right? I believe that is the entire assembly that has the *****, a/c and audio buttons, and the display. I am assuming mine is bad since I can't seem to find any sort of fix anywhere on the net
Old May 13, 2011 | 3:51 PM
Get the P/N and then check it at gmpartsdirect.com.
Old May 16, 2011 | 8:51 AM
gamecock's Avatar
$139 on that website. I am going to order it..now if I can just get the cover off without breaking it. I can easily get the tabs on the top popped up - but the rest seems to be stuck in there pretty good. Any tips for removing this? How many clips does it have and where are they?
Old May 17, 2011 | 2:53 PM
Official GM Rep
gamecock,
Please be sure to keep us updated when the issue has been taken care of. If you have any questions please contact Jeff directly.
Thank you,
Caron, Chevrolet Customer Service
Old Jun 2, 2011 | 1:18 PM
08burbltz's Avatar
Same issue here on an 08 Suburban LTZ that I just purchased. Mine has no *****, just buttons. Rear heated seats, auto air settings, source, vol, etc.... Is this a common issue?
