Rear Power lift gate
Old Aug 26, 2009 | 11:02 PM
  #11
Your best bet is the Helm Factory manuals for about $150 www.helminc.com
the 150 for these manuals will pay for them selves on the first major repair...
Or you can try a subscription to alldata...
Or wait and see who post the info for you....
Old Nov 11, 2009 | 3:56 PM
  #12
JPBall's Avatar
Default Multiple Visits for this same issue
Our 2007 Suburban exhibited similar characteristics.
First, the lift gate groaned, made excessive noise, or failed to lift or close. The dealership "lubricated" the hydraulic struts.
Of course the problem returned <12 months later, but the symptoms were far more aggressive. The lift gate "stumbled" or "hopped" it's way up and down and frequently failed to open or close, sometimes behaving as if it encountered an obstruction and returned to it's starting position (up or down). The dealership "replaced" the hydraulic struts.
Fast forward another 12 months and the lift gate begins exhibiting the same issues, and eventually the motor simply makes a grinding noise and fails to lift or close. This time the dealer proposes a new lift gate module (motor). The installed cost is $975.00.
Chevrolet/GM have a problem with this feature and it's clear that weight and alignment conspire in some way to stress the hydraulic lifts and eventually stress the lift gate module. Perhaps an insufficient number if incidents has been reported to make this a more important issue for GM, but this should clearly be a warranty issue, regardless of mileage.
Old Nov 30, 2009 | 6:32 AM
  #13
Damien0869
Guest
Posts: n/a
Hi Barry ...you are on the right track, I experienced the EXACT same issue, along with the door going up and back down and stopping before closed position. I am only left with a gawd awful humming noise and no activity from the door.
My Hoe is getting fixed Tuesday. The Latch Module is defective and being changed (advised GM is experiencing issues with this module) and the Power Lift gate Actuator Motor is being replaced, as to prevent the popping from re-occurring.
Now i just wanted to write you as to let you know that, when you change either part, you will need to do a "re-learn" process on the latch module. Unfortunately, this can only be done Via GM Tech II scanner. I hope you have a source to provide this procedure for you.
Good luck Fella, cheers
DAM
Old Dec 16, 2009 | 6:47 PM
  #14
FLGatorLTZ's Avatar
Default Any Updates
Hi Barry,
I just purchased a 2007 Suburban and the power lift gate is displaying the same symptoms as yours. It appears that the latch is trying to release, followed by the lift motor... then it stops and 3 chimes sound and everything stops. The gate will partially become ajared but will not open. Would love to find out if you were able to fix the problem.
Thanks.
Jon
Old Feb 25, 2011 | 1:21 PM
  #15
chadfetter's Avatar
What does one need to remove to get access to the liftgate motor/assembly? Mine is doing the same thing.
Old Feb 25, 2011 | 1:57 PM
  #16
I think you just have to remove the left rear trim panel.
RJK
Aug 2, 2019 5:50 PM
TomS209
Jul 23, 2015 12:22 PM
Dropdprpls10
Aug 28, 2014 8:56 PM
frank2004
Jan 2, 2011 9:30 PM
FRANE
Sep 12, 2008 12:30 PM
