Rear third stop light
Old Aug 9, 2010 | 4:18 PM
Classical Glass's Avatar
Default Rear third stop light
I want to get at the wireing on the rear third tail light to install a safety flasher. I see there is a large oval rubber boot on the upper portion of the rear hatch. i tryed to remove it to look under it but it wont budge. Is there some king of trick to remove it? All I want to do is get at the two wires that go to the light. Thanks for your time...
Old Aug 9, 2010 | 4:20 PM
Default Rear third tail light
Sorry I forgot to mention my Tahoe is a 2007.
Thanks....
Old Aug 9, 2010 | 9:02 PM
What year and model?
Old Aug 9, 2010 | 9:06 PM
I can't swear to it but I'd bet the boot has a gromet type flair on the hidden end,
you may be able to collapse it with a small tipped screw driver and some silicone lube by probing into the outer edge of the hole that you can expose...
Old Aug 10, 2010 | 7:18 AM
SabrToothSqrl's Avatar
Default removal
Mine came off easy when I was going to replace it w/a 'smoked' one... there was 2 wires you could easily tap...
I wonder if you could add like another light to each side... have some big *** HMCSLs....
Old Aug 10, 2010 | 3:37 PM
I got the grommet off does any one know what color wires go to the third light? Not much room to work in there. It's on a 2007 tahoe.
Thanks...
Old Aug 16, 2010 | 2:25 PM
See https://chevroletforum.com/forum/tahoe-suburban-25/2007-tahoe-third-brake-light-wire-diagram-35075/
RomanGuzi
Oct 2, 2011 11:40 AM
oldmako
Jun 17, 2008 11:00 PM
Scruffydogtoo
Apr 4, 2008 9:02 PM
rabbit0102030
Apr 1, 2008 8:24 PM
rpmax2
Jan 7, 2008 10:14 PM
