Rear window defroster
The coiled wire connection to the rear window defroster has come disconnected from the metal connection on the window glass. What can be used to put this connection back? I assume current must pass thru the connection or is it just heat? Is there a special adhesive that is used?
Will silver loaded conductive epoxy work? I know that it works for repairing broken grid lines where the tint guys get a little over zealous when trimming to match the lines. [
seems to be a big issue in colder states. my glass was replaced 2 times by gm under warranty on my 07 for this problem alone. finally on the 3rd time i tried to fix my self using conductive epoxy. well the clip has not come off, but the defroster currently is not working. i think i am going to try to add a bead of solder to connect the clip to defroster line...
philco
Mar 31, 2007 10:59 AM
