Remote door lock stops working
Old Jan 7, 2014 | 9:34 AM
Omar Segovia's Avatar
Default Remote door lock stops working
I have a 2007 Chevy Tahoe purchased just about 8 months ago. When I bought it the remote worked fine. About 3 months later it stopped working. Now it only works if I unlock the driver door with the key first it will work. It will also work right after u turn it off and get off, I am able to lock the doors with the remote. Wait about 2 minutes after that and it wont work anymore. I got some programming instructions for the remote from a local locksmith but still didn't fix. Any suggestions on what the problem might be?
Old Jan 7, 2014 | 10:59 AM
Did you change the battery?
Old Jan 8, 2014 | 3:43 PM
No Nothing got changed. The Remote just started doing that
Old Jan 9, 2014 | 11:17 AM
The remote could be going bad. Put a new battery in the remote and try it again. If that doesn't work then you probably will have to replace the remote.
Old Jan 9, 2014 | 12:36 PM
I have already tried the new batteries at the local locksmith but still same issue. When I bought the Tahoe it came with 2 remotes and same issue on both. I don't think its a problem with the remotes
Old Jan 19, 2014 | 12:21 PM
chevy2dalevy's Avatar
Default May be RCDLR problem
Look at the 4th item in this old thread.
https://chevroletforum.com/forum/tah...list-07s-4039/
cnterline
40
Dec 9, 2021 11:48 AM
stanman
Camaro
Jan 7, 2012 4:12 AM
wad5520
Dec 2, 2011 10:51 AM
Mastiff
Jul 12, 2010 8:39 PM
Hank501
Jun 5, 2010 9:34 PM
