Remote Starter Questions
Old Dec 5, 2006 | 5:03 PM
86K5350's Avatar
Default Remote Starter Questions
I have installed a remote starter on older vehicles with no problems. Does an 02 Suburban need a bypass or anything special to install? Also does anyone recommend a specific brand?
Old Dec 7, 2006 | 12:26 AM
golfer's Avatar
Default RE: Remote Starter Questions
Yes and no.
The reason I said it that way is your vehicle has the Passlock 2 anti theft system. This is the yellow ( + ) and orange / black ( - ) wires in the ignition harness.
When you turn the key to start the cylinder sends a resistance value to the BCM to disable the anti theft.
Most remote start systems and installers will say ( for extra cost ) you require a by pass module. All these modules are ; a variety of resistance values that are selected for your particular vehicle to match that of your key cylinder ( previously explained ). If you were to read the value yourself then go to an electronics supply shop , get the resistance value ( use precision resistors within 1% ) and install it on the yellow wire ( if I recall ) this will work. At least this has for me on my 99 Malibu and 03 S10.
bavant
Jan 16, 2012 2:12 PM
scotte2051
Nov 27, 2011 10:41 PM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
chachas
HHR
Oct 31, 2009 1:37 PM
