remove captains chairs
Old Mar 22, 2020 | 3:00 PM
  #11
why is it complicated?
Old Apr 29, 2020 | 2:46 AM
  #12
Mittos's Avatar
Default packing and moving companies near me
Originally Posted by in2pro
They should have 4 blots holding them down at each corner, disconnect the electrical connectors and tuck them under the carpet....
Here packing and moving companies near me company G&J Moving.
I have not removed the seats so I can't say specifically if its studs coming up with a nut holding them down or a bolt through the seat to the frame...
You will either need to place the bolts back in the holes to seal them up to prevent water and exhaust gases from coming back into the cabin... if they are studs sticking up you will need to cap them some how to prevent them from being penetrating objects....
But yes the seats can be removed....
Yes, that's right
Old Jan 12, 2022 | 8:27 AM
  #13
Kcampbell's Avatar
Default Carpet removal.
Originally Posted by bird
I remove my Captain Chairs often. I have since laid down a 3/4" piece of 4'x8' plywood that I covered with Auto carpet to "flatdeck" the back of my burb.
Each of the captain chairs has 4 nuts and one plug. If you prop your seats up, you can pull up on the carpet covered flooring underneath the seat. It should pop right off, and then you can see the four nuts. I take the seats out via the rear access, think they're too big for the side door.
Here's a video: How to Remove your 07 & Newer 2nd Row Bench Seat - YouTube
Do you still have the video on removing the 2nd row seats? I clicked on it and it said it was private. Also, do you have any links to a video showing what all is involved with removing the entire carpet? I have a 2007 Tahoe. Thanks!
rruelas
May 24, 2022 9:42 AM
stevekremer
Feb 6, 2018 5:27 PM
fury
Jan 2, 2016 1:23 AM
gmlover
Mar 5, 2015 10:00 AM
mrseric
Mar 24, 2009 7:13 AM
