remove captains chairs
Old Apr 14, 2014 | 7:05 AM
sclifton's Avatar
Default remove captains chairs
How do you remove the 2nd row captain's chairs in 2009 suburban
Old Apr 14, 2014 | 9:54 AM
SabrToothSqrl's Avatar
Default ...
for the purpose of?
replacing w/bench?
having more 3rd row leg room?
I assume you can just unbolt them, but I know mine are power flip and heated, so there's a lot more to it...
Old Apr 14, 2014 | 11:18 AM
sclifton's Avatar
Default remove 2nd row captIn's chairs
I want more space as I carry dogs. My seats are heated also.
Old Apr 14, 2014 | 12:09 PM
They should have 4 blots holding them down at each corner, disconnect the electrical connectors and tuck them under the carpet....
I have not removed the seats so I can't say specifically if its studs coming up with a nut holding them down or a bolt through the seat to the frame...
You will either need to place the bolts back in the holes to seal them up to prevent water and exhaust gases from coming back into the cabin... if they are studs sticking up you will need to cap them some how to prevent them from being penetrating objects....
But yes the seats can be removed....
bird's Avatar
I remove my Captain Chairs often. I have since laid down a 3/4" piece of 4'x8' plywood that I covered with Auto carpet to "flatdeck" the back of my burb.
Each of the captain chairs has 4 nuts and one plug. If you prop your seats up, you can pull up on the carpet covered flooring underneath the seat. It should pop right off, and then you can see the four nuts. I take the seats out via the rear access, think they're too big for the side door.
Here's a video:
Old Apr 14, 2014 | 12:23 PM
Excellent video how-to
Old Apr 14, 2014 | 12:54 PM
Neat. I took out my 3rd row, and used some MDF covered in automotive carpet, and made a flat floor for the back of mine.
Old Mar 22, 2020 | 11:47 AM
Ron Weszely's Avatar
Default Remove captain's chairs
How do you remove the 2nd row powered Captain chairs in a 2007 suburban LTZ to make more space?
Old Mar 22, 2020 | 2:14 PM
isn't the answer up above?
they're usually just bolted down. Did you look under the seat?
Old Mar 22, 2020 | 2:54 PM
Default Removal of seats is not obvious
Obviously you have not looked at a 2007 to 2014 ish suburban. The powered 2nd row seats appear to be very complicated to get out. The video above that is no longer available may have been helpful. So I was simply looking for someone with a few tricks up their sleeve to help.
