remove headrest
Old May 15, 2007 | 7:34 PM
jms88's Avatar
Default remove headrest
I need to remove the headrest from a 1997 suburban to install a seat cover - there is a small hole on the base of each headrest but no button - any ideas on how to remove it? Thanks in advance
Old May 16, 2007 | 8:45 AM
lost_in_alabama's Avatar
Default RE: remove headrest
It sounds like the button is broken off. Try inserting a small screwdriver into the hole to press what the button did.
Old May 19, 2007 | 4:16 PM
southern slammer's Avatar
hey there, the little pin hole u have on the side is how you remove the headrest all u need is a small pin or micro screwdriver and insert in hole and lift headrest out,and you will be set to install your cover.
Flawdafred
JesseyJames01
Mar 4, 2008 7:33 PM
RockstarDaddy
Jun 29, 2007 6:25 AM
jmuck
Apr 28, 2007 10:39 PM
xclusive
Feb 8, 2007 6:29 PM
Biggmon
Jan 14, 2007 2:24 AM
