Tahoe & SuburbanThe power, space, and brutal towing ability make the Tahoe and its longer sibling, the Suburban, arguably the best full size SUV's on the market today.
I was getting very annoyed when every time I'd start my 2022 Suburban, the SiriusXM Preview screen would override any other radio stations I was previously listening to before turning off my car. I finally found out the solution is simply using the little rectangular drop-down box in the upper left corner of the display that read "SiriusXM" to select either AM or FM, and then shut off the car. The next time it starts, it will be the station you were just listening to. See picture for that drop-down box.
Update: the above only worked for less than one day, and it continues to revert to the SiriusXM screen every day. If anyone knows how to remedy this, I'd love to know!
I found a way guys to keep the Sirius XM display from popping up on my 2022 Silverado, I was not able to remove it but if I leave it on FM and do not turn the radio off ever, I can turn it down and turn it up when I get out of the truck and the truck is turned off overnight, when I started back in it it's right back on the same radio station it does not go to the Sirius XM display on the screens , however if you turn your radio off then it converts back to the sirus XM display every time, I just leave it on I turn it down I never see that display again that was so Damn aggravating, and I can still switch to phone and Bluetooth and back as long as you don't turn radio completely off , give it a try and hopefully it works for y'all as well
there is no fix for this problem i went to the dealer about it and all they said was we have to roll back the last update that had Serius and not have it update the system anymore. i tried going into the system and remove it all together but it keeps coming back
