Removed the driveshaft and now it spins
Old Mar 2, 2012 | 7:10 PM
gpro's Avatar
Default Removed the driveshaft and now it spins
I have an issue getting my suburban to get into gear and I thought it was the transfer case. In the process of removing the transfer case, I removed the driveshaft. Out of curiosity I turned on the engine and engaged to reverse and to my surprise I can see the internal shaft in the transfer case spinning. Could the rear drivetrain preventing my suburban from moving? I put the it on neutral and remove the brakes and jacked up the rear tires and it doesn't spin freely. Is my rear-end stuck? Any ideas or suggestions would be appreciated.
Thanks
ro
Old Mar 2, 2012 | 8:54 PM
inthechateau's Avatar
with drive shaft disconnected from rear diff yoke, can you put a pair of plyers or a pipe wrench and turn the yoke by hand? If not you have a siezed pinion bearing at the least. If yoke can be spun it is in the xfer case. My bet with 10 bolts in these trucks is a pinion bearing. Pull the fill plug and see if any gear oil runs out. if not you have your answer. Look for a new/used rear with same gearing.
Old Mar 6, 2012 | 6:51 PM
gpro's Avatar
I opened the differential cover (14 bolts) and it looks to have enough oil in it. I have the brakes off and the truck on neutral. How much force do i need to turn the wheels?
Old Mar 6, 2012 | 9:47 PM
avgas's Avatar
If you have the wheels lifted off the ground you should be able to turn the pinion gear by hand providing the parking brake is released. It does not take much effort to turn the pinion gear.
Travizzle317
Oct 23, 2014 9:32 AM
gmt900
Sep 16, 2008 4:52 PM
bdk00
Feb 28, 2008 3:06 AM
05 Z71
Oct 9, 2007 6:47 AM
5thgeartapped
Nov 15, 2006 12:44 AM
