Replacing '02 dash with '03+ double din bezel - tips for modifying climate controls?
Old Nov 27, 2020 | 3:51 PM
Sintek's Avatar
Default Replacing '02 dash with '03+ double din bezel - tips for modifying climate controls?
I ordered an OEM dash bezel for '03+ Tahoes and such so I could install a double din head unit in my '02 Tahoe and am looking for advice on integrating it with the non-digital climate controls. I knew going in that the climate controls would be the only obstacle, but based on what I read I assumed it would be a relatively simple process of relocating the control unit up or down when in fact the bezel won't fit over the controls and they can't be installed after since the opening is too small.
Is this simply a case of cutting it to size? Is there any other way?
Thanks for any help.
In an almost completely unrelated question, can resetting the PCM multiple times in a short time cause any issues? I've been working on and off installing audio gear and am to the point that I must occasionally connect the power to test and then remove the negative cable again to fix any problems and continue working.
Ernie Clayton
Avalanche
Mar 11, 2016 3:18 AM
Rconce01
Oct 8, 2009 4:16 PM
Joepoppa1
Oct 4, 2009 11:20 PM
twarner776
Feb 10, 2009 3:24 PM
punkieys17
Mar 10, 2008 8:05 AM
