Replacing Autoride Rear Suspension - Tips
Old Jan 4, 2014 | 1:10 PM
  #11
joeincharlotte's Avatar
Thanks for the tips. I just finished mine today. Did the compressor and the shocks. I should have taken the wheel well cover off to work on the compressor. Didn't realize it was so accessible until I started on the shocks. On the passenger side, all of the rear A/C lines got in the way when I was trying to get the top bolt off. Couldn't get to it with anything until I found a crazy wrench in my grandfather's stuff that just happened to fit.
I didn't need to compress the shocks at all, they slid right into place with a little up and down from the floor jack on the axle housing.
All in all a pretty easy install, happy to have it working again.
Old Jan 6, 2014 | 6:38 PM
  #12
07TahoeLTZ---'s Avatar
Update on my repair:
New shocks feel good, but I still have an air leak somewhere. Had a bunch of people in the car the other day and the compressor kept running. When it gets a little warmer I'll have to check the compressor and air lines, but has anyone else had a similar issue?
Old Jan 21, 2014 | 5:26 PM
  #13
Did you get any information? I noticed the same thing. When I hooked the boat up this weekend it leveled out properly, and after about 5 minutes of idling the compressor started back up again.
Gonna need to get under there and see if I can find a hole in one of the air lines. I can't seem to find a part number for the lines. Anyone have that?
Old Jan 31, 2014 | 5:55 PM
  #14
Sorry for the late reply, but I haven't had the chance to check out my leak. Hopefully we will get some warmer temps soon.
Old Apr 2, 2015 | 12:46 AM
  #15
Wosby's Avatar
Default Retainer Clip
Does anyone know where to get those little plastic clips that lock the air supply hose to the air-shock? The dealer suggested I purchase a new set of hoses that come with the clips.
Old Apr 2, 2015 | 6:19 AM
  #16
TWard's Avatar
recommend you go to the bone yard, or if you hung on to your old compressor, harvest some clips off of that assembly.
Faceman
Sep 5, 2024 7:19 PM
Jarwade
Jul 10, 2020 3:01 AM
Nic.Pollinger
Mar 25, 2014 1:17 PM
ginfield
Jul 27, 2013 1:50 PM
akabavah
Avalanche
Oct 10, 2009 9:54 PM
