Replacing Idle Air Control Valve
Old Aug 7, 2010 | 6:14 PM
mgobluetex's Avatar
Default Replacing Idle Air Control Valve
I have figured out that the issue causing my 2001 Chevy Tahoe to have RPM issues when at a stop light or parked is the idle control valve. Does anyone have any idea how to replace or where to find it? All of the information that I have found online refers to ICV's that are cord driven and my Tahoe controlled by an electric throttle. Any help would be appreciated. It is hot outside and I want to get this fixed so that I can have AC when stopped. Thanks a lot for all information!!!
Old Aug 7, 2010 | 10:18 PM
maxxman04's Avatar
idle air control valves are all electrical, whether the throttle is cable or electric doesn't matter. iac's are mounted on the throttle body itself, usually with 2 bolts/screws, and an electrical connector. this link shows the iac for the 5.3 motor.
http://www.oreillyauto.com/site/c/de...2169&ppt=C0018
Old Aug 7, 2010 | 10:25 PM
mgobluetex's Avatar
I have the part but I just don't see where it goes. Is it right next to the Alternator?
Old Aug 7, 2010 | 10:36 PM
maxxman04's Avatar
it goes on the throttle body, which is on the top of motor where the air goes into engine. you'll have to take the air intake tube off, then look on drivers or passenger side of the throttle body (the throttle body is basically the carberator looking part)
Old Oct 29, 2010 | 2:51 AM
javedjee77's Avatar
Default cleveland taxi
Thanks for this
Old Oct 29, 2010 | 8:06 AM
also take a read of this artical and see if it might apply..
http://ww2.justanswer.com/uploads/Bl...e_cleaning.pdf
454BBC
Apr 30, 2013 5:48 PM
TahoeMatt
Feb 28, 2013 8:13 PM
RScottYukon
Feb 17, 2013 8:18 PM
83_Caprice_Classic
Sep 21, 2010 2:12 PM
