replacing turn signal switch
95 Tahoe and I need to replace the turn signal switch and have a question do I need to remove the steering wheel to replace the switch ?
Thanks for your help.
It should be accessible once you remove the wheel shroud... no need to remove the steering wheel... if i recall on my 97, I had to use some funky inverted torx bits to remove the shroud....
I didn't have to replace my switch, but I did have to access the wire harness/connector going to it...
fishingpro77
HHR
August 4th, 2016 12:44 AM
RomanGuzi
October 2nd, 2011 11:40 AM
