replacing turn signal switch
Old Apr 7, 2013 | 7:36 PM
OkieMudslinger's Avatar
Default replacing turn signal switch
95 Tahoe and I need to replace the turn signal switch and have a question do I need to remove the steering wheel to replace the switch ?
Thanks for your help.
Old Apr 8, 2013 | 6:41 AM
It should be accessible once you remove the wheel shroud... no need to remove the steering wheel... if i recall on my 97, I had to use some funky inverted torx bits to remove the shroud....
I didn't have to replace my switch, but I did have to access the wire harness/connector going to it...
Old Apr 8, 2013 | 7:52 AM
thanks I'm replacing it because the high beam switch quit working.
fishingpro77
HHR
Aug 4, 2016 12:44 AM
loced27
Apr 17, 2013 1:50 AM
RacerX
Jun 11, 2012 4:54 PM
RomanGuzi
Oct 2, 2011 11:40 AM
geepee1
Jun 11, 2006 11:48 AM
