rim question
Old Oct 20, 2011 | 6:25 PM
new2this's Avatar
Default rim question
i have a 97 tahoe 2wd and i was wondering will 08 z71 rims fit on my tahoe ? also if they do fit does anyone have pictures this?
Old Oct 21, 2011 | 9:24 AM
SabrToothSqrl's Avatar
Default No
I don't believe they will, they changed the bolt pattern in 07.
tirerack.com select your car, then pick some wheels...
Old Oct 21, 2011 | 9:54 AM
91Caprice's Avatar
I believe the 2wd Hoes have the 5x5 bolt pattern. If you had the 4x4 with the 6 lug pattern it would fit.
Old Oct 29, 2011 | 1:18 AM
new2this's Avatar
what would i have to do to convert to 6 lug?
Old Oct 29, 2011 | 11:43 AM
SWHouston's Avatar
You'd have to change your Axles out to the 6 Lug,
I'm not sure that would be worth it !
Old Nov 1, 2011 | 10:34 AM
91Caprice's Avatar
I've never done it personally but I know it's been done a lot as I've seen a lot of write ups on it. If you do a Google search on the subject you should come up with a lot of useful information.
Old Nov 1, 2011 | 1:59 PM
Default cost
it will cost WAY more to convert your truck between axles, brakes, links, fitting, etc.
it will be much more cost effective to just find wheels you know fit...
98Z71
Apr 25, 2012 7:19 AM
cbarry77
Sep 2, 2011 11:01 AM
country_09
Nov 9, 2009 3:04 PM
gruichn1
Aug 10, 2007 11:12 AM
