roof rack mounting bolts
Old Mar 29, 2013 | 7:12 AM
OkieMudslinger's Avatar
Default roof rack mounting bolts
I did a search trying to find out what size the bolts are that mount the rack to the roof. I have a 95 Tahoe and the PO removed the roof rack and I'm going to mount a light bar to the old front mounting holes if I can find out what size they are. so thanks for the help.
Old Mar 29, 2013 | 9:56 AM
mulmur1's Avatar
It may be best to go to local hardware store and take an approx measurement and get a few bolts to try. You may be able to order them direct from your GM dealer, but they will be expensive.
I looked on gmpartsdirect.com and they do not list the bolt separately. They only listed the assembly.
This site lists the bolts. It appears that there are a couple different sizes.
BOLT. Luggage Roof. LUGGAGE CARRIER; LUGGAGE CARRIER ( ); LUGGAGE CARRIER ( ). 1996 Chevrolet Tahoe 4WD # 12387478
Good luck with the light bar.
Old Mar 29, 2013 | 11:59 AM
mulmur1's Approach would probably be mine as well, size up the hole and threads and pick up a few bolts... I'd be my guess that its something like a M6 or M8 though being a 95 it could be SAE and not metric... probably about 24 to 28 threads per inch...?
jniolon
Dec 30, 2010 11:41 AM
Faceman
Dec 27, 2010 4:34 PM
KMeloney
May 13, 2009 10:34 AM
m_49tahoe
Jul 25, 2007 1:13 AM
