Rough Idle/hesitation
Old Mar 6, 2025 | 5:28 PM
jay48's Avatar
Default Rough Idle/hesitation
Howdy race fans.
So I just enjoyed to whole changing the charcoal filter/blowing out the carbon out of the gas tank vents drama, and then my engine started running very bad. I supposed I had gobbered something but I wasn't finding anything.
However, it was acting like a spark plug wire was grounding out - I didn't hear anything but that's the way it was behaving. I had recently added some red "Made in China" wires and assumed that might be the issue (only a month old but the coil end on some of the wire connectors wasn't centered on a couple of the wires - had to fight to get them seated). Rough idle and hesitation when first accelerating was the issue. At speed, it seemed to run OK...sort of. I did notice the instant MPG was lower than I was use to seeing (17 vice 21 MPG @ 55 MPH).
Changed out the wires (again) and replaced all eight coils - it runs like a new truck (2013 Suburban 180K)! I found #6 coil had a missing section on the bottom - I hadn't see that during all my fiddling. The post was wet too - that's right below where the heater hoses connect at the firewall...yeah, I had replaced those plastic heater hose connectors about three years ago. However, I've seen drips at that connection since; but it's not flowing or have I smelled antifreeze.
Recommend you consider this
"parts cannon" if you're chasing a similar problem.
Happy motoring!
[img alt="Busted coil cap.
"]https://cimg9.ibsrv.net/gimg/chevroletforum.com-vbulletin/215x201/coil_75452435692d085cdb765ed4b2adf43aa4b94851.jpg[/img]
Busted coil cap.
pjking
Aug 6, 2016 12:28 AM
jcausarmy
Feb 13, 2015 7:28 AM
SethUpchurch
Jun 3, 2013 10:06 AM
mnchevy56
Mar 17, 2013 9:13 PM
63Nova707
Jul 22, 2012 9:22 PM
