Rubbing Noise
Old Sep 9, 2024 | 12:50 PM
JimmyC's Avatar
Default Rubbing Noise
2022 Tahoe makes rubbing noise when making left turns...anyone familiar with this issue?
Old Oct 23, 2024 | 2:40 PM
javi2377's Avatar
Default 2022 Tahoe Rubbing Noises
My 22 Tahoe makes rubbing/moaning noises more pronounced in the mornings when I’m pulling out of the driveway or making tight turns. Here’s a special bulletin that I found on the web that hopefully will help you. I’ve researched through other forums and this is an issue that there seems to be no straightforward solution for it. I called my dealership and they said that if the noise was coming from the rear differential that’s covered under the powertrain, but my noise is coming from the front. So I don’t know frustrating
File Type: pdf
GreaseMonkey4x4
Jun 25, 2012 10:01 AM
rervf23
Aug 14, 2011 11:30 AM
emarch42
Mar 17, 2010 9:09 PM
TRProffitt
Jan 10, 2009 9:16 PM
mandyc
Jan 3, 2008 8:56 AM
