Rubbing sound when turning
#21
Always a good idea to check the service bulletins for your vehicle . Nice find.
Apparently the dealer techs never learned.
#22
Going Dec. 18th Monday and printed out that bulletin so that when I drive with tech I can also show that. Will let you know what happens.
#23
Getting worse
The groaning/rubbing sound has been getting worse. I tried to use 4 high when it was snowing. It was jerking and clunking while turning and accelerating and I had to take it out of 4 high. I was not making tight turns. It also did the same thing in 4 high once. I have my second appointment at the dealer tomorrow.
#24
My dealership just told me they needed to replace the rear end... I don't think they attempted just changing fluids... So we are on a wait-list and told to not drive it any more than needed...
#25
Update
#26
I went and drove with tech after they could not duplicate AGAIN. I got in the car and it started making noise right away - the tech was surprised - but shouldn't have been. They still have the car so hopefully they can replace rather then just flush and put new lubricant because all that will do is mask the issue and probably get worse later, anyone thinking of selling or trading in?! Really fed up with all of this back and forth. By the way I also took the paper of the bulletin with this issue - they acted like they didn't know, crazy.
#27
Same noise
21 Tahoe Z71 in S FLA… Been dealing with same issue for over a year. Working directly with GM after filing complaint with BBB. Truck has been at dealer over 5 times with each stay 2+ weeks. So far they have replaced 4x4 actuator, axels, and most recently the front diff each time they have had a GM field service engineer see the vehicle. Just picked it up yesterday and noise still present. Only resolution provided has been giving us GM reward points and extending drive train warranty. We are beyond frustrated.
#28
vromerot1 (December 29th, 2023)
#29
Hi, Thanks for sharing...Mine is still making noise after the flushing and driving the miles suggested, will be making another appointment. However, it seems you have been with this issue a long time and nothing has fixed it, what will you do next? I'm seriously over it as well.
#30
