Scanner wont link/ truck wont start/ Paypal reward
Old Feb 8, 2019 | 6:05 AM
  #11
Tyler Aijalon Lucas's Avatar
Originally Posted by sleepingciv
Ok this truck has been something else lol.
First off its a 99 Tahoe with a 5.7 automatic.
The truck does have air ride so it has been modified.
Since I got the truck there were starting issues. Hard to start but would start.
So getting more into it. I gave the truck a wire tuck. Moved the Pcm and fuse box and firewall plugs to inside of the truck.
Also removed a car alarm that didnt work I dont believe. Any wires that were removed from the alarm were just spliced onto the wire, meaning no stock wire was ever cut to add the alarm. The old connection have been resealed up.
So anyway, I get the wire tuck done. Go to start the truck and it runs for like 1-2 seconds then dies. will do this over and over.
Have 60psi at prime then drops to roughly 56ish psi after start up and die. Its a e2000 pump.
So after going threw all my wiring which is solder and heat shrunk, and was cut one wire at a time and labeled and or number. Everything looks good.
There were some plugs in the engine bay that were not hooked up like the washer bottle the abs stuff that I deleted from the truck, so i dont think thats it, cause the truck ran with out these plugs plugged in before.
So after a few days of searching and thinking maybe its the passlock, and trying to reset it which never worked. Truck still does the same thing.
Finally broke down and bought a obdII scanner and went to hook it up. Turned key to on then plugged in the scanner, it powers up but wont link.
So I tested the power and ground and they are both good. Then I ohm'd out the data link purple wire to the pcm and it reads out. I dont know the specs for that wire, but I got a reading meaning its connected.
Also I did noticed that the cluster lights did flash off and on but would stop.
Im lost on what it could be. I have welded on the truck battery disconnected.
I have added grounds and double check that all plugs are plugged in and all grounds are connected.All fuses are good. Although from sometime before I got the truck I did notice the horn relay is melted I have taken that relay out and the wires are not melted or anything.
Just lost really need some help lol.
If anyone can help me and actually figure this out Ill paypal ya a little something
Try changing your ignition switch with harness ,that's a known problem for chevy trucks. I had the same problem 99 silverado 5.3 liter. The security light wouldn't go off,cluster blinking on and off. Changed ignition switch with harness problem solved
Old Feb 24, 2019 | 1:25 AM
  #12
Tahoe_Hybrid's Avatar
this thread is very old just do the "passlock bypass"
Old Jul 24, 2020 | 3:54 PM
  #13
Blue Beast's Avatar
Default Passive immoblizer
You probably tripped the passive immobilizer.
Starts but hard quit right away .
Old Jul 25, 2020 | 1:03 PM
  #14
Cusser's Avatar
When my 1994 Suburban could not connect to scanner, it was the fuse labeled "CIGAR" that had burned out. Yes, that fuse controls the communications.
dukester544600
Oct 6, 2018 12:43 PM
RYDREW55
Nov 9, 2010 8:31 AM
dukester544600
Jul 31, 2009 4:30 PM
dtb305
Jan 18, 2007 12:11 AM
Jefft0825
Nov 21, 2006 1:41 PM
