Service Traction Control - Stabilitrak and ABS light, Help
Be sure that they change the terminating resistor in the wiring harness.( near the spare tire underneath the truck) and change the battery cables. that is what cured my problems.
Hey guys,
Not sure if this is going to apply to many/any of you, but, I recently changed my rear shock and had the same lights all come on. I searched exhaustedly online and found a whole bunch of useless solutions about reseting the codes by disconnecting the battery to replacing VSS (I didn't even bother with the last one). It seems nobody wants to post the error they made while working back there (or at least the one I did), above the shock tower on the back side where it is impossible to see, there is a connection that controls all of this and is very easy to unplug not so easy to plug.
Perhaps this is the issue you are having being intermittent and being effected by water and WD40, maybe it wouldn't hurt to clean these contacts, put some di-electric grease on them and re connect. could be a lot less trouble then having the dealership look at it endlessly.
Sorry to all if this is not the appropriate spot for this post, my internet is painfully slow (I live out in the sticks) but if someone else can fix it or place it where it needs to be I and probably others with this problem would appreciate it.
Good luck and thanks for the space and knowledge base!
I signed up for this because it seems chev monitors it as i see reps responding. i'm having all the problems listed below on my 2010 tahoe for months. service stabilitrak light flashes then locks cycle followed by guages failing always happens at random times. Dealer has looked at it several times and after seeming to get it to work the problem comes back. They are looking at all modules as when we finally get a check engine light it calls out codes for all modules. most recently the dealer even tried unhooking the onstar in effort to fix. too many of us having these common problems. Has chev got any fix in the works? don't dare drive this truck any distance from from home as afraid will get stranded. real bummer. please help.
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Have you contacted Customer Service regarding these issues? If so, would you please PM me and provide your Service Request number (SR#) for your case and the last 8-digits of your VIN, so I may look into this further? Louis
GM Customer Service
It sounds very similar to the problem I was having with my 07 Tahoe. after dealers changer a bunch of the control modules to no avail, the cure for mine was found to the the terminating resistor in the wiring LAN wiring harness and the resistance was too high in the battery cables. that would be the cheapest place to start. if the terminating resistor is bad it will cause codes for all the modules as they would be "confused" due to the bad resistor.
Mine is at the dealer now. I tried to explain everything I've read in the above posts. They nodded and said "uh huh" I said that I hope we don't simply chase parts, reset codes, and pray.
They just called with an estimate. ABS Module, wheel speed sensor, throttle body module all need to be replaced, as well as a Evap canister. $2600.
I called BS and told them to hold off. Any recommendations?
Jeff
07 LTZ Suburban, stock except for K&N filter, 89k miles
Jeff
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
Louis
GM Customer Service
GM Customer Service
