Service Traction Control - Steering Position Sensor
Old Dec 21, 2012 | 12:59 PM
babaganoush's Avatar
Default Service Traction Control - Steering Position Sensor
I have a 2008 Tahoe that is giving a "Traction Control Off" "Service Traction Control" message. It has been doing it for months. The local dealership has tried 4 or 5 times and they cannot seem to fix it. The code they get is for a faulty steering position sensor. they have replaced the sensor twice as well as followed a bulletin recommendation to adjust the connectivity/fit of the sensor. They also did an alignment which seemed to have the best results, I didn't get the warning for a couple months. It's back now and is happening every day. What options do I have? Do I just give up and accept that a major vehicle safety feature is non operable? -Frustrating.
Old Dec 21, 2012 | 3:15 PM
Official GM Rep
<!--[if gte mso 9]><xml> <oocumentProperties> <o:Author>Joy Hotchkiss</o:Author> <o:Version>11.9999</o:Version> </oocumentProperties> </xml><![endif]--><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> babaganoush,
I’m sorry you are experiencing this issue with your vehicle. I would like to look into this further for you, and create a case. In order to proceed, would you please provide the following information: your full name, address, phone number, vehicle mileage, VIN and the name and city of your dealer?
I look forward to your reply.
Louis
GM Customer Service
Old Aug 17, 2021 | 8:16 AM
PlumbRight's Avatar
Default 2006 suburban
I have an 06 with several issues. Anyone figure this out?
Old Aug 17, 2021 | 11:43 AM
hanky's Avatar
How about some more info?
You are not giving us much to go on.
Old Aug 18, 2021 | 11:42 PM
PlumbRight's Avatar
Sorry. My fault. I was in a rush and this truck is stressing me out.
I blew a brake line 2 weeks aweeks noticed that the brake lines (all of them) that run under the driver side by the Frame, from front to back, were very very corroded. I cut all of them and used brass compression couplings to piece new line in between the cut sections. While working or bleeding, possibly, the brake fluid reservoir went dry. When I turned the key back on the traction control is showing a light for malfunction. It says service stabilitrak, it says service brakes, my parking brake light is on. It's a mess and I can't handle the inoperative method.
Old Aug 20, 2021 | 7:05 AM
repairman54's Avatar
Compression fittings on brake lines is dangerous, they have to be flared fitting connections. Compression fittings will blow out on a panic stop.
ABS pump probably has air in it and needs a scan tool to purge the air out of it is the second issue.
islandarmor
Avalanche
323
Sep 18, 2025 1:09 PM
dirtyfrank
Feb 29, 2012 9:09 PM
JR Sllim
Feb 17, 2012 3:32 PM
wmc3
Feb 10, 2012 3:21 PM
lsufan88
Feb 4, 2012 10:31 AM
