shaking in the rear? 2000 limited Tahoe
Old Aug 14, 2012 | 8:27 PM
mike1's Avatar
Exclamation shaking in the rear? 2000 limited Tahoe
ok i have a 2000 Limited Tahoe. I have a shaking in the rear of the Tahoe. i have put new wheels and tires, new shocks and it is still shaking. Nobody can tell me what the problem is? So any help would be great!!!
Thanks
Old Aug 14, 2012 | 9:54 PM
MDTAHOE's Avatar
Professional Mechanic
When does it shake?
Old Aug 15, 2012 | 7:20 AM
mike1's Avatar
It starts around 50. it is very little but when you get to 60 it gets worse and then at 70 it bad!!! I mean so bad its almost like the truck is going to come apart.
Old Aug 15, 2012 | 12:15 PM
SWHouston's Avatar
Get that thing up on a Floor Jack (single point of lift under diff) and put it in gear.
Look at the wheels (round/wobble/balance) check the drive shaft for straight and maybe a clip is missing out of the rear U-Joint.
Old Aug 15, 2012 | 9:03 PM
MDTAHOE's Avatar
Is it worse when you accelerate?
Old Aug 15, 2012 | 9:46 PM
mike1's Avatar
i put it up on a life today and wheels are walking a little on the rear tires? It only shakes bad at 60-70.
Old Aug 15, 2012 | 9:49 PM
mike1's Avatar
rear u joint is fine and tight. The tires walk like i said. The drive shaft looks good.
Old Aug 16, 2012 | 11:21 AM
SWHouston's Avatar
What do you mean by "walk" ?
Old Aug 18, 2012 | 6:39 PM
mike1's Avatar
they are wobbling a little but not bad.
snoski
May 18, 2010 2:39 PM
atis
Apr 12, 2010 8:00 PM
MadMullen13
Sep 17, 2007 1:07 PM
steveb2833
Mar 17, 2006 4:30 PM
