She died......
She died on the freeway..
1986 suburban
4x4, 5.7/th400
carburetor
Man oh man....
I was driving down the freeway going 70 mph and all the sudden it died... threw it in neutral and started it again and all it did was let out a huge backfire.... got it towed home at 1 AM....
In the last six months i did a full tune up (cap, rotor, plugs, coil, wires, fuel filter, etc, etc)...
I've been messing with it all day today, but all i can get it to fire briefly, then sputter out, all the while slightly backfiring and coughing out the carburetor...
I am sure fuel is pumping, but need someone to help me confirm the spark, but being that it keeps starting and backfiring, i would assume that the spark is fine....
I noticed today that the muffler blew it top off when it backfired on the freeway! I've never seen that before! That musta been a hard backfire!
I would guess that the timing chain advanced..... what would you guys think???
Any idea fellas????
4x4, 5.7/th400
carburetor
Man oh man....
Any idea fellas????
Welcome to the forum.
Before I read the rest of your post, timing chain was the first thing I thought of. But I think if it slipped a couple of teeth, it would retard timing. Which could actually cause ignition as the exhaust valve is opening.
all right fellas! I got the timing cover off and set everything to TDC, but the rotor in the damn distributor is pointing at cylinder FIVE, not ONE.
So, the timing chain and gear/sprocket all look solid with little play at all, and no teeth are missing... I am guessing that I should pull the distributor out and check the gear on the end of it....
Well, I guess the first question should be: How much play should there be on the timing chain?
What would you fellas recommend?
Timing chain should be tite. So you're saying that the punch marks on the crank gear and the cam gear line up? I suspect the chain has jumped several teeth unless you find something wrong w/ the dist. gear.
Well, i finally found the time to work on the truck again. LOTS of work = NO TIME to play with truck.
So. this is what i found. The timing marks are lined up 12 o'clock (cam) and 12 o'clock (crank). This is a DTC piston #1. Is this right? I heard that this should be 6 and 12 as opposed to 12 and 12.
Is this normal?
I thought the cam gear should be at 6:00 and crank gear at 12:00 or IOW pointing at each other.
Bottom line is that when #1 is at TDC, both valves should be closed.
And yes, you need to do a compression check or pull the valve covers to ensure no bent valves.
I too believe that they are supposed to point at each other, that is how you know its lined up...
Tim G
August 13th, 2013 4:03 PM
For Sale: She's gotta go
maxxman04
10
December 22nd, 2010 9:39 PM
