She died......
Old May 21, 2011 | 6:26 PM
burbinman's Avatar
Default She died......
She died on the freeway..
1986 suburban
4x4, 5.7/th400
carburetor
Man oh man....
I was driving down the freeway going 70 mph and all the sudden it died... threw it in neutral and started it again and all it did was let out a huge backfire.... got it towed home at 1 AM....
In the last six months i did a full tune up (cap, rotor, plugs, coil, wires, fuel filter, etc, etc)...
I've been messing with it all day today, but all i can get it to fire briefly, then sputter out, all the while slightly backfiring and coughing out the carburetor...
I am sure fuel is pumping, but need someone to help me confirm the spark, but being that it keeps starting and backfiring, i would assume that the spark is fine....
I noticed today that the muffler blew it top off when it backfired on the freeway! I've never seen that before! That musta been a hard backfire!
I would guess that the timing chain advanced..... what would you guys think???
Any idea fellas????
Old May 21, 2011 | 8:50 PM
Welcome to the forum.
Before I read the rest of your post, timing chain was the first thing I thought of. But I think if it slipped a couple of teeth, it would retard timing. Which could actually cause ignition as the exhaust valve is opening.
Old May 22, 2011 | 1:31 PM
burbinman's Avatar
all right fellas! I got the timing cover off and set everything to TDC, but the rotor in the damn distributor is pointing at cylinder FIVE, not ONE.
So, the timing chain and gear/sprocket all look solid with little play at all, and no teeth are missing... I am guessing that I should pull the distributor out and check the gear on the end of it....
Well, I guess the first question should be: How much play should there be on the timing chain?
What would you fellas recommend?
Old May 22, 2011 | 5:11 PM
Timing chain should be tite. So you're saying that the punch marks on the crank gear and the cam gear line up? I suspect the chain has jumped several teeth unless you find something wrong w/ the dist. gear.
Old May 30, 2011 | 12:18 PM
burbinman's Avatar
Well, i finally found the time to work on the truck again. LOTS of work = NO TIME to play with truck.
So. this is what i found. The timing marks are lined up 12 o'clock (cam) and 12 o'clock (crank). This is a DTC piston #1. Is this right? I heard that this should be 6 and 12 as opposed to 12 and 12.
Old May 30, 2011 | 6:54 PM
burbinman's Avatar
I did not find anything wrong with the dist. gear, but shouldn't i be at DTC on cyl 1 when the timing marks are lined up?? The only time I find TDC on cyl 1 is when the timing marks are both at the 12 o'clock position.
Is this normal?
Old May 31, 2011 | 6:47 AM
shamrock246's Avatar
should be 12 and 12,and the cam dowel pin at 9 o'clock position
Sean
97 4x4 burb
Old May 31, 2011 | 9:56 PM
I thought the cam gear should be at 6:00 and crank gear at 12:00 or IOW pointing at each other.
Bottom line is that when #1 is at TDC, both valves should be closed.
And yes, you need to do a compression check or pull the valve covers to ensure no bent valves.
Old May 31, 2011 | 10:03 PM
I too believe that they are supposed to point at each other, that is how you know its lined up...
Old Jun 1, 2011 | 3:56 PM
JimJ's Avatar
Unless you have a 2 cycle engine, #1 needs to be at TDC on the compression stroke and not on the exhaust stroke.
Tim G
Aug 13, 2013 4:03 PM
RacerX
Jun 19, 2012 4:26 PM
maxxman04
10
Dec 22, 2010 9:39 PM
rebel8ball
Aug 9, 2009 1:57 PM
