shift lever stuck in park
Old Mar 3, 2018 | 5:39 PM
  #11
Wyocowboy's Avatar
Originally Posted by in2pro
See if these help any, and no, the links in the document are not clickable as they reside on my PC....
Hey in2pro. After tryiing what you had sent me about the shift solenoid and it checked out ok, I finally figured out what was wrong. It is kind of one of those "how dumb can I be" times. I had replaced the ignition lock cylinder, casing and switch. When I put the new switch in, the gear was not meshed with the lock cylinder so that the switch did not turn enough so the shifter would work. I got to thinking about it yesterday and took the switch out, bumped the gear up a couple of notches to the last one and what do you know, it works!
I still do have a lingering problem that actually led to all of the trouble in the first place. Periodically, the battery warning light comes on when I turn the engine off and remove the key. I had noticed I could shut it off before by reinserting the key and twisting it back. I got to thinking the cylinder lock and switch were probably wearing out. I couldn't get the damn cylinder lock out of the casing so I replaced the casing also. But that did not solve the problem. the battery light turns off when the engine is running but still comes on when the key is off. I think now it probably is a short somewhere so I am going to try to chase it down. If I don't watch it close, it will run the battery down overnight. Any thoughts.
Old Oct 23, 2022 | 10:53 PM
  #12
Siever1988's Avatar
Did you ever figure it out ? I am having the same problem I changed the lock cylinder and case the switch was off I got it and then one day I turned my truck around backed it up and next morning would go out of park . I've replaced the switch . The brake light switch. Shift interlock solenoid and still stuck in park
