Side mirrors move on their own when shift to reverse
Old Mar 27, 2019 | 3:39 PM
Fsufam's Avatar
Default Side mirrors move on their own when shift to reverse
All,
Whenever I put my 05 Tahoe into reverse the side mirrors move on their own. What makes them do this and how can I get it to stop? It's really kind of annoying...
Thanks...
Old Mar 28, 2019 | 7:48 AM
Kazoocruiser's Avatar
From: Currently the Candian Gander is wintering over in New York.
There might be a fuse that you can disconnect, or a wire that feed a signal when the vehicle is placed in "Reverse".. You might lose your ability to adjust them electrically if you pull the fuse, though.
The mirror jog was a "feature" that was supposed to help drivers have a wider field of view when backing.
The thing is, you are supposed to back into parking places, anyway, so you have a clear view when pulling out of a parking place, so mirrors wagging like Dumbo ears is kind of technology pandering.
By the way, welcome, but this help request should really have been put into another section instead of this one. Maybe a Mod or Admin will move the thread to a relevant forum.
Old Mar 28, 2019 | 8:06 AM
Fsufam's Avatar
Default Ok, so I figured out the problem and it is now not a problem
The issue was the mirrors we're set to adjust in the vehicle settings in the cluster display. I turned off the mirror adjustment when in reverse so now it is just fine. I don't normally back into a parking place so it was a function I wouldn't use and like I said, it was pretty annoying. Thanks to anyone who replied and had a suggestion for the issue...
