Smoke coming from cylinder 8 area
Old Dec 27, 2021 | 3:40 PM
Burban04's Avatar
Default Smoke coming from cylinder 8 area
Made a quick video. https://youtube.com/shorts/K7dGugQOBUo?feature=share Smoke doesn't look like it's coming from the spark plug. Just below it to where I can't see. This randomly started after sitting for repair. Smokes as soon as it's started from a cold start here in Montana. Not too thick. Hard to tell if it's a sweet smell or oil. I live in the mountains and our 1 mechanic is out for good. Trying to save a 2 hour trip with smoking issues.
Old Dec 28, 2021 | 8:23 AM
JPCaveman's Avatar
That's usually oil leaking from a valve cover or whatever. It runs down the side of the head until it gets to a point that's hot enough to make it smoke. Look at it with a good light and maybe a mirror just above where the smoke is coming from. Fresh oil is glossy, old is dull because it has dirt stuck to it. When you find the highest point of the trail you've found the source.
Old Dec 28, 2021 | 9:50 AM
Burban04's Avatar
Thank you. That was my first thought. What made me think it could be something else is that from cold 15 degree start it will smoke instantly. Could still be the case. I ordered a new gasket and I'm going to pull the valve cover off when I can, clean it, install new gaskets and hope that helps.
Old Dec 29, 2021 | 8:46 AM
repairman54's Avatar
Check your heater hose connection at the heater core. Do you have a rear heater in it? If so, there is a T connector there as well. I just had to replace the T connector in my Tahoe. Coolant drips right down on the #8 coil and right down on the exhaust manifold.
Old Dec 30, 2021 | 11:55 AM
Burban04's Avatar
I'll check that out as well. Trying to get through the busy holidays first and then knock that out
mpyrol
Avalanche
Nov 17, 2019 11:35 AM
trueblue
May 25, 2017 1:34 PM
mmoore031908
Mar 14, 2014 8:39 PM
tentenmarschel
Sep 1, 2012 6:44 PM
BigRed922
Apr 9, 2012 8:18 PM
