Spark Plug Wire
Old Apr 18, 2010 | 12:04 PM
fudog's Avatar
Default Spark Plug Wire
How do you remove the spark plug boot with the metal jacket around it from the plug? It does not want to come off. This is on a 2003 Chevy Tahoe. Thanks
Old Apr 18, 2010 | 12:09 PM
maxxman04's Avatar
pull hard. seriously. they make a tool just for this to that grips the boot, but if it's on there that good, you might expect to replace the wires cause it will probably break.
Old Apr 19, 2010 | 3:44 AM
mudmaniac's Avatar
Ride of the Month
May 2009
Also try rotating it back and forth a little to make sure it's not stuck on.
Old Apr 19, 2010 | 4:17 PM
Put some silicone grease in the boot to prevent it from sticking next time. Also helps keep moisture out.
Old Apr 24, 2010 | 1:43 AM
mikeross's Avatar
Good suggestion. Just what I did when to remove the spark plug wires boot. it sure did the trick.
mamulan
Aug 20, 2014 8:39 AM
TPM
May 14, 2013 5:58 PM
Simplejack
Feb 7, 2012 7:28 PM
teamtexas
Apr 4, 2009 9:28 PM
braggent
Jun 19, 2006 12:25 PM
