Spark plugs
indexing
Yes indexinging the plug to direct maximum spark directed toward combustion chamber Hmmm OK heres what i got, If i remember correctly, it was used primarily by drag racers back in the day and even then the h.p. gain-increase was fairly if at all noticable, . but if you would like to give it a try LOL heres how! you must (shim) each plug to reach desired direction of spark toward combustion chamber and still maintain proper plug torque settings ! old schoolers used washers of various thickness homemade ground in 2 to 5 thousands increments. ya know, what with the new hei and comp. controlled systems and reconfigured heads and comb. chambers and on and on its not really necessary in present times, these powerplants burn hot and clean sooo long story short its a real pain in the a.. ! But always a good story to share with other gearheads over a cold one ! hope this helps some what
tv
what was the year and make of the car ? did it have angled plugs or straight plugs ? was it carberated or fuel injected ? throttle body or multi port What brand and type of heads ? and finally just how much h.p. and torque did the dyno results? show im intrested in this application and what was the proceedure that they used and what precautions and warnings for this application did they comment on, just a comparison on applications that i have done and what the newest or up to date tech's have to say like i said im intrested let me know thanks
Ride of the Month
May 2009
Ride of the Month
May 2009
I saw that same episode about indexing, I have never done it myself but it seams to make sense. I think it was mainly and add for a product of indexing spacers they were promoting.
catill
August 30th, 2010 11:07 AM
dbrog28301
Colorado
May 21st, 2007 9:48 PM
epekarik
July 14th, 2006 12:51 AM
