Speedometer stopped working
Old Jan 25, 2020 | 7:56 AM
toddhegstrom@gmail.com's Avatar
Default Speedometer stopped working
2003 suburban speedo abruptly stopped working. All other guages are fine. Any tips on diagnosis. Receiving unit in cluster ( have seen utube videos on replacing ) or sending unit to high not exactly sure where that is . Or advice on fixing
Old Jan 25, 2020 | 8:14 AM
kevinkpk's Avatar
Just had mine fixed, local shop. Remove the bezel, that's the trim piece around it, just need thumb power. Remove 4 7mm screws, and disconnect. I had the shop add transmission temperature gauge since I tow a trailer on occasion, Mine is also a 2003. The speedometer didn't just stop, but got erratic,.
Old Jan 25, 2020 | 8:52 AM
Irish_alley's Avatar
I'm here for the party
i know these years have bad stepper motors but like kevin mentioned they usually just dont stop working but more go into an erratic mode. im not sure if a cluster replacement would fix your issue or if you have another issue. im not sure how you can even test them. on my 04 imp 4 out of the 6 gauges went bad and started reading erratic but none never stopped just working. replaced the stepper motors and problem went away
Old Jan 25, 2020 | 12:36 PM
If it is the stepper motor, you can replace it yourself if you can solder. I did mine in a 03 Trailblazer a few years ago. It was so easy I ended up changing all 6 since they would have gone bad anyway.
Old Jan 25, 2020 | 12:41 PM
Default Agree
agree. Complete sudden stop so was reluctant to do what you did. Anyone know how to test sending unit at tranny. ? And where is it ?
Old Jan 25, 2020 | 1:00 PM
kevinkpk's Avatar
It's driver side transmission about 2/3 way back. It's easy to get too. I don't know how to test one, other than the end should be magnetic.
Old Jan 25, 2020 | 1:46 PM
yeah i dont know how to test those other than replacing or plugging in a code scanner so you can see what the computer is reading for speed
Dcowbys
1988 - 1998 (GMT400)
Nov 27, 2019 5:55 AM
ipm
Sonic (Aveo)
May 29, 2015 5:06 AM
PRISTINEBAY
Mar 25, 2015 6:58 AM
cdbrock24
Mar 27, 2012 11:51 AM
Harmsie
Uplander
Jun 2, 2008 9:41 AM
