Squawks and Resistance
Old Sep 25, 2011 | 6:30 PM
  #11
The Eaton G80 diff is a locker. I don't think there's any kind of limited slip in the front.
Old Sep 25, 2011 | 6:51 PM
  #12
mercracing's Avatar
Theres no point to put a limited slip in the front. When you have the truck in 4X4 auto, when slip is detected, the 4X4 is engaged
Old Sep 25, 2011 | 7:43 PM
  #13
legolas894's Avatar
Just a question-Is it doing this when you turn or when you turn and put the brakes on? I had an issue where if I put my brakes on it a sharp left turn, the abs activated at low speeds. Ended up disconnecting the speed sensors and that solved the problem.
Old Sep 26, 2011 | 1:01 AM
  #14
SWHouston's Avatar
No, brakes were never involved. My statement was that (apparently) because of the complete lock between the front wheels, when I turned, it literally stopped the vehicle, and it doesn't take long to do that either. One has to apply quite a bit of throttle, to overcome that and keep going. It's pretty clear NOW, why they say don't use 4x4 on dry pavement ! !
As far as the 4x4 Auto...
That seems the way to go, if you are driving across various surfaces. Just let it do what it wants to/what's needed.
But, does it select HI or LO 4X ?
I remember reading that you should drop your speed below 3 mph (I think it said) before you change "modes". Does that apply to "Auto", or will it auto-engage the 4X4 mode, at any speed ?
Old Sep 27, 2011 | 2:58 PM
  #15
I believe the owner's manual is very detailed about the different functions and how they work.
chris 419
May 23, 2012 5:25 PM
jesse06
Mar 3, 2012 5:37 PM
wolfe
Jul 25, 2011 10:37 AM
