Squealing Brakes on 2009 Tahoe
Old Sep 18, 2012 | 9:56 PM
Bill C.'s Avatar
Smile Squealing Brakes on 2009 Tahoe
I have replaced the rear brake pads and rotors on both rear wheels on my 2009 Tahoe and I still have a squealing noise coming from the rear wheels when I apply the brakes. Any suggestions? Thanks
Old Sep 18, 2012 | 10:39 PM
MDTAHOE's Avatar
Professional Mechanic
Are you sure it the rear? What brand parts did you use?
Old Sep 18, 2012 | 10:47 PM
BrandonHHR's Avatar
I agree. Make sure it is the rear brakes. It can be very hard to tell sometimes. And honestly it seems like a Chevy trait to have squeaky brakes. Owned a 2007 impala, brakes squeaked. 2010 Malibu, brakes squeaked. 2009 HHR, brakes squeak. All with low mileage.
Old Sep 19, 2012 | 8:53 AM
rrhodes1970's Avatar
Also note that semi-metallic have a tendency to squeal. I use Ceramic and mine are very quiet.
Old Sep 19, 2012 | 1:13 PM
SWHouston's Avatar
There are some "remedies" you can buy that may help...
Ref:
How to Fix Squeaky Brakes: DIY Auto - Popular Mechanics
Old Sep 19, 2012 | 2:31 PM
I second the ceramic pads and the application of an anti squeal compound applied to the BACK of the pads... also cleaning and proper lube of the caliper pins to ensure smooth and quick movement of the unit
Old Sep 19, 2012 | 9:49 PM
Bill C.'s Avatar
Thanks to everyone for their replies. I had a local mechanic shop do the work for me. They did replace the pads twice with a different brand of pads, but I do not know the name brand. I will get that information and post it shortly. We picked the vehicle up tonight and my wife says the brakes are still squealing. I think they tried to apply the compound to the back of the pads today. I'm still pretty sure the squealing noise is coming from the rear brakes. Thaks for your answers.
Old Sep 20, 2012 | 7:21 AM
cleveland63b's Avatar
all contact surfaces should be lubed and the rotor needs a good finish on it otherwise it'll squeak regardless of pad quality
Old Sep 20, 2012 | 3:09 PM
Also they must not touch or otherwise contaminate the friction surface of the pads and rotors.
Old Sep 21, 2012 | 2:56 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Bill C.,
Were you able to resolve this issue?
Please feel free to contact me privately if you have additional questions.
Louis
GM Customer Service
