Stabilitrac ABS
Stabilitrac ABS
Hi All,
I have a 2004 Tahoe AWD. About 6 months ago my stabilitrak started engaging while i was driving at slower speeds. Mostly when i was accelerating from a stop. the throttle body and sensor has been replaced recently. also the 2 wheel speed sensors on the front wheels and still it comes on, i just turn it off while driving for a few months, but then the ABS would engage all the time. mostly it happened when I am slowly coming to a stop and it engages. i have resorted to pulling the ABS fuse. Drives fine just dash lights, but I'd really like a fix for this, and ABS is nice so is stabilitrak, when they function normally. btw NO CODES either.
Thanks
Thanks
Codes get retained in all the modules memory's unless the battery gets disconnected or goes dead.
A good code reader is more important than hand tools on today's vehicles as knowing the codes gives you a direction to go in and a full scan is always any shops first thing to do when lights and warnings are present.
Azaghal
September 20th, 2016 11:15 PM
