Stabilitrac ABS
Old Nov 29, 2021 | 10:28 AM
badmoon007's Avatar
Default Stabilitrac ABS
Hi All,
I have a 2004 Tahoe AWD. About 6 months ago my stabilitrak started engaging while i was driving at slower speeds. Mostly when i was accelerating from a stop. the throttle body and sensor has been replaced recently. also the 2 wheel speed sensors on the front wheels and still it comes on, i just turn it off while driving for a few months, but then the ABS would engage all the time. mostly it happened when I am slowly coming to a stop and it engages. i have resorted to pulling the ABS fuse. Drives fine just dash lights, but I'd really like a fix for this, and ABS is nice so is stabilitrak, when they function normally. btw NO CODES either.
Thanks
Old Nov 30, 2021 | 7:28 AM
repairman54's Avatar
Scanning with a full spectrum scanner?
Most code readers will not do all 4 code families. ABS codes are not P codes.
Old Nov 30, 2021 | 1:42 PM
badmoon007's Avatar
No not a full spectrum. So even without an on dash warning, would it throw a code that a full spectrum scanner would read?
Old Dec 1, 2021 | 6:45 AM
Codes get retained in all the modules memory's unless the battery gets disconnected or goes dead.
A good code reader is more important than hand tools on today's vehicles as knowing the codes gives you a direction to go in and a full scan is always any shops first thing to do when lights and warnings are present.
Azaghal
Sep 20, 2016 11:15 PM
chino4allu@gmail.com
Aug 17, 2016 3:13 PM
71Corvette
Dec 21, 2014 11:00 AM
mark121268
Feb 26, 2012 12:39 AM
CeS
Mar 11, 2011 5:14 PM
