Stablitrac/Traction Check Lite
2007 Tahoe LTZ with 30,000 miles.
The Stabilitrac/Traction Control Check Lite came on and stayed on. I stopped and turned the engine off and restarted the engine, the Check Lite stayed on.
Stopped for supper and the Lite was off when I started the Tahoe to come home.
Do I have a problem coming. I will appreciate your input.
I had this happen also on our 07 Tahoe. both lights were on and the truck was not driveable. I turned it off for a few minutes then restarted and everything was fine. It does talk about this in the manual - so many sensors have to talk just right for everything to work
The chk brake lite came on in conjunction with the stabilitrak lite so I checked the master cylinder and found the brake fluid was low.
After filling it, everything is now fine.
